Dafor
Nov 06, 2015Follower
WNCE3001 keeps connecting for a second then becomes limited.
I followed the instructions, I got to the setup page, entered everthing, and in the last review step, it just says that the page is unavailable on chrome. The light is solid green. which I guess mean...
JamesGL
Nov 11, 2015NETGEAR Employee Retired
Hi Dafor,
How far is the adapter from the router? Can you check if the firmware is the latest one? If not, you may check the link below for the firmware.
http://downloadcenter.netgear.com/en/product/WNCE3001#searchResults
JamesGL
Community Team
