mrsixstrings12's avatar
May 25, 2017
wnce3001 LAN link down
Hello! I am trying to use my netgear wnce3001 to allow an aquarium controller to be accessed wirelessly. The wnce3001 displays a solid green light, showing that it is connected to my home internet. W...
  • JamesGL's avatar
    JamesGL
    Jun 12, 2017
    Hi mrsixstrings12,
    Configure the adapter first using the computer. Since it can go online, then connect it to the controller. Set the controllers IP in same range as the router.
