mrsixstrings12
May 25, 2017Aspirant
wnce3001 LAN link down
Hello! I am trying to use my netgear wnce3001 to allow an aquarium controller to be accessed wirelessly. The wnce3001 displays a solid green light, showing that it is connected to my home internet. W...
- Jun 12, 2017
Hi mrsixstrings12,
Configure the adapter first using the computer. Since it can go online, then connect it to the controller. Set the controllers IP in same range as the router.
mrsixstrings12
Jun 08, 2017Aspirant
I currently have the adapter plugged into my macbook, the macbook's wireless is turned off, and the internet is working perfectly fine. It seems the issue is the adapter and aquarium controller communicating.
JamesGL
Jun 12, 2017NETGEAR Employee Retired
Hi mrsixstrings12,
