JRn900
Aug 15, 2016Aspirant
WNCE4004 cannot connect to Cisco XB3 from Xfinity
Just got new Comcast Router - Cisco XB3 and cannot connect thru the Genie software. Gets to the last part of setup and says move unit closer to router.Is there something I'm missing? Is this n900 400...
JamesGL
Aug 17, 2016NETGEAR Employee Retired
Hi JRn900,
1. How far is the WNCE4004 from the router?
2. Make sure that the router does not have MAC filtering. If you are not sure, check with the manufacturer.
3. Reset the adapter and reconfigure.
JamesGL
Community Team
JRn900
Aug 20, 2016Aspirant
Adapter is in same location as it was with previous Comcast router. Not sure how to check MAC filtering on router. It appears to connect with the router momentarily but drops at the end of the process.
- JamesGLAug 28, 2016NETGEAR Employee Retired
Hi JRn900,
Check with router's manufacturer and make sure that MAC filtering is not enabled. Try to lower down as well the security of the wireless network and change channel.
JamesGL
Community Team - JamesGLSep 01, 2016NETGEAR Employee Retired
Hi JRn900,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team- JRn900Sep 02, 2016Aspirant
Had some trouble figuring out how to get to the XB3 settings, but finally did. There is an option to DENY MAC Filtering for channel 2.4 ghz and I selected that. However, getting same result. Can you elaborate on Changing Channel and also what to do to lower the security level?
- JamesGLSep 04, 2016NETGEAR Employee Retired
Hi JRn900,
Make sure the MAC filtering is disabled. For channel, check the wireless settings, there should be an option to change it from 1-11.
JamesGL
Community Team
