JRn900
Aug 15, 2016Aspirant
WNCE4004 cannot connect to Cisco XB3 from Xfinity
Just got new Comcast Router - Cisco XB3 and cannot connect thru the Genie software. Gets to the last part of setup and says move unit closer to router.Is there something I'm missing? Is this n900 400...
JRn900
Aug 20, 2016Aspirant
Adapter is in same location as it was with previous Comcast router. Not sure how to check MAC filtering on router. It appears to connect with the router momentarily but drops at the end of the process.
JamesGL
Aug 28, 2016NETGEAR Employee Retired
Hi JRn900,
Check with router's manufacturer and make sure that MAC filtering is not enabled. Try to lower down as well the security of the wireless network and change channel.
JamesGL
Community Team
