Budgie4
Nov 29, 2016Tutor
WNCE4004 How can I change the static IP
I do not have WPS so followed the instructions for installation without WPS. Problem is that the device has a fixed IP (192.168.1.240) and therefore I have to set lan address on my pc to same subnet...
JamesGL
Jan 03, 2017NETGEAR Employee Retired
Hi Budgie4,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
Budgie4
Jan 03, 2017Tutor
Hi James and thanks for the follow up. I am not yet able to confirm all is well. I am still trying to diagnose a problem which is not, I trust, due to WNCE4004 but by fixing its IP address in band I want to remove one of the uncertainties so hopefully I can pin down problem. Will post again when hopefully I have solved the problem. Thanks again. Budgie
- JamesGLJan 18, 2017NETGEAR Employee Retired
Hi Budgie4,
Any updates on your issue?
JamesGL
Community Team- Budgie4Jan 19, 2017TutorHi and many thanks for the follow up which is appreciated. I have not had much success with my WNCE4004 and only slightly better luck with a Linksys WET54G. The problem is getting long term reliable bridge function for a multimedia device which uses UPnP/multicast to establish and maintain communication with control app on phone. No body has an authoritative answer to this problem and it is not clear to me if problem is with bridge device or main wifi AP or both. If you have any answers please let me know. I cannot be the only person seeking to control his media player with a phone app over a wifi bridge!!!
- JamesGLFeb 02, 2017NETGEAR Employee Retired
Hi Budgie4,
Do you have other devices that you can connect to the WNCE4004? This is just to test if the WNCE4004 is working and stable.
JamesGL
Community Team
