davidcasper1
Sep 28, 2016Follower
WNCE4004 will not connect
This problem has already been raised - but was closed with no answer. See: https://community.netgear.com/t5/WiFi-Adapters/WNCE4004-will-not-connect-with-AC1750-router-despite-multiple/td-p/976279 ...
fscout42
Jan 15, 2017Aspirant
Hi, it's already a while ago, since this topic came up. But just want to say I encounter the same problem. I just bought an extender EX7300 and replaced my EX6200 which I still use it but in another configuration. I thought this EX7300 is downward compatible. But obviously not. I wanted to connect the wnce4004 to the new extender but no luck. It refuses to connect to the EX7300 extender. Tried WPS and manual via ethernet cable connected to my laptop. And it's indeed not the wnce4004. Cause it connects fast and easy to my Vodafone easy.box as well as to my ex6200. But not to my new EX7300. So what is wrong with that?
Any ideas and maybe a solution? So far I've found nothing which could help to connect the wnce4004 to the EX7300.
Thanks a lot.
JamesGL
Jan 18, 2017NETGEAR Employee Retired
Hi fscout42,
Do you have other wireless devices that works with the EX7300?
