davidcasper1
Sep 28, 2016Follower
WNCE4004 will not connect
This problem has already been raised - but was closed with no answer. See: https://community.netgear.com/t5/WiFi-Adapters/WNCE4004-will-not-connect-with-AC1750-router-despite-multiple/td-p/976279 ...
JamesGL
Jan 18, 2017NETGEAR Employee Retired
Hi fscout42,
Do you have other wireless devices that works with the EX7300?
fscout42
Jan 18, 2017Aspirant
Hello James, yes I have. A Samsung TV, a mini-PC and my receiver (Yamaha RX-V777). All devices seem to connect except this wnce4004.
- JamesGLJan 29, 2017NETGEAR Employee Retired
Hi fscout42,
Will it work if you will connect it directly to the routers network?
- fscout42Jan 30, 2017Aspirant
Hello James,
yes, it does connect to my Vodafone EasyBox as well as to my Netgear router R7000. No problems at all with these devices. Only the EX7300 refuses the connection.
That's the current setup now. The thing is the distance. It's not very good.
- JamesGLFeb 19, 2017NETGEAR Employee Retired
Hi fscout42,
Try resetting both the EX7300 and the WNCE4004 and reconfigure them.
- JamesGLFeb 23, 2017NETGEAR Employee Retired
Hi fscout42,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
