davidcasper1
Sep 28, 2016Follower
WNCE4004 will not connect
This problem has already been raised - but was closed with no answer. See: https://community.netgear.com/t5/WiFi-Adapters/WNCE4004-will-not-connect-with-AC1750-router-despite-multiple/td-p/976279 ...
JamesGL
Jan 29, 2017NETGEAR Employee Retired
Hi fscout42,
Will it work if you will connect it directly to the routers network?
JamesGL
Feb 19, 2017NETGEAR Employee Retired
Hi fscout42,
Try resetting both the EX7300 and the WNCE4004 and reconfigure them.
- JamesGLFeb 23, 2017NETGEAR Employee Retired
Hi fscout42,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- fscout42Feb 24, 2017Aspirant
Hello James,
have just reset both devices. WNCE4004 won't connect to EX7300. Neither via cable connected to my laptop using the web gui nor via WPS. This device drives me crazy and I'm fed up with it now. I'll put it in the trash can and get rid of it. It's all a waste of time.
So no further assistance needed.
Thanks a lot for your help.
Roland
- JamesGLFeb 28, 2017NETGEAR Employee Retired
Hi fscout42,
Let me check on this issue and will provide you feedback.
