LoneWolf12
Aug 16, 2015Aspirant
wnce4004 with TG1682G issues
My signal strength is at 100% but my wnce4004 refuses to connect while other devices have no problem. After inputing my passkey my wnce4004 tells me "move your device closer to your router or gateway...
JamesGL
Aug 17, 2015NETGEAR Employee Retired
Hi LoneWolf12,
Welcome to Community!
Can you provide the current firmware version of the adapter? Check if MAC filtering is disabled on your router. It will block new device connecting to your network.
JamesGL
Community Team
- LoneWolf12Aug 18, 2015Aspirant
Of course my wnce4004 is at "V1.0.0.32." My TG1682G has no disable option under mac filter but it is set to "Allow-All".
The "allow-all" feature does the following:
Allow-All(default):All wireless client stations can connect to the Gateway; no Mac filtering rules.
- JamesGLAug 21, 2015NETGEAR Employee Retired
Can you install the WNCE4004 close to th main router. Try to install it about 5 feet away from the router. If the same problem, reset the adapter to factory default.
JamesGL
Community Team
- LoneWolf12Sep 15, 2015Aspirant
Still no solution the only thing that will make it work is if I change my gateway to the older model i use to have.
