Vadim_'s avatar
Vadim_
WNDA 3100 v.3
The question is - has v.3 significant changes in hardware and firmware? I mean, for examle, if v.2 worked with TV Panasonic, do v.3 will work with it too?
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi Vadim_,
    Welcome to Community!
    These units are running on different driver versions. Not necessarily that if v.2 works with Panasonic then the v.3 should work as well. It depends on the software/driver if the said feature is available.
    JamesGL
    Community Team
    • Vadim_'s avatar
      Vadim_
      Hi!
      Thank you!
      Before I read your answer, I tried v.3 with Panasonic TX-PR42UT30. It doesn't work with this TV.
      • JamesGL's avatar
        JamesGL
        Vadim_,
        I guess the reason for that is it might not be compatible with the Panasonic TV and only the version.
        JamesGL
        Community Team
