scrum111
Nov 26, 2015Follower
Wnda3100v2 Orange Light only!
This device has never worked for me in the past, so I gave up on it. This past week, I needed to use it, so I plugged it into a usb port on my pc, and it worked magically. It was amazingly fast! Then...
JamesGL
Nov 28, 2015NETGEAR Employee Retired
Hi scrum111,
Amber light indicates that the adapter is connected to the 2.4Ghz network of your router. If the router supports 5Ghz, you may try connecting to it and blue light will lit.
