McGoo01
Aug 06, 2015Aspirant
WNDA3100v2 Region Change
Ever since I bought this N600 WiFi Dual Band USB Adapter I had trouple with the connection to my home network. One day it works fine, another day it doesn´t work at all. I have the newest version o...
JamesGL
Aug 17, 2015NETGEAR Employee Retired
Hi McGoo01,
Welcome to Community!
Were you able to download the driver for US? Or can you only see driver for Europe region? Please provide the link of the download page.
JamesGL
Community Team
- McGoo01Aug 19, 2015Aspirant
Hallo JamesGL,
here is the link for the download:
http://downloadcenter.netgear.com/#register
I found a solution for my problem. I bought a TP-Link WiFi Range Extender TL-WA850RE, and with this one
the connection works fine. So, my logical explanation would be: The cause of the problem is the Arris-TG862-Router
from Brighthouse. But every other wireless device works great with the router, even from the same location. So,
I don´t know. At least I have a functioning system now.
McGoo01
- JamesGLAug 20, 2015NETGEAR Employee Retired
Hi McGoo01,
Would it be possible to install it on a different computer and check if it has the same problem.
JamesGL
Community Team
- McGoo01Aug 23, 2015Aspirant
Hallo JamesGL,
actually my PC is already the 2nd PC I´ve tried, my son´s PC was the 1st one. And yes, the problem occurs
on both PCs.
McGoo01
