McGoo01
Aug 06, 2015Aspirant
WNDA3100v2 Region Change
Ever since I bought this N600 WiFi Dual Band USB Adapter I had trouple with the connection to my home network. One day it works fine, another day it doesn´t work at all. I have the newest version o...
McGoo01
Aug 19, 2015Aspirant
Hallo JamesGL,
here is the link for the download:
http://downloadcenter.netgear.com/#register
I found a solution for my problem. I bought a TP-Link WiFi Range Extender TL-WA850RE, and with this one
the connection works fine. So, my logical explanation would be: The cause of the problem is the Arris-TG862-Router
from Brighthouse. But every other wireless device works great with the router, even from the same location. So,
I don´t know. At least I have a functioning system now.
McGoo01
JamesGL
Aug 20, 2015NETGEAR Employee Retired
Hi McGoo01,
Would it be possible to install it on a different computer and check if it has the same problem.
JamesGL
Community Team
- McGoo01Aug 23, 2015Aspirant
Hallo JamesGL,
actually my PC is already the 2nd PC I´ve tried, my son´s PC was the 1st one. And yes, the problem occurs
on both PCs.
McGoo01
