McGoo01
Aug 06, 2015Aspirant
WNDA3100v2 Region Change
Ever since I bought this N600 WiFi Dual Band USB Adapter I had trouple with the connection to my home network. One day it works fine, another day it doesn´t work at all. I have the newest version o...
JamesGL
Aug 20, 2015NETGEAR Employee Retired
Hi McGoo01,
Would it be possible to install it on a different computer and check if it has the same problem.
JamesGL
Community Team
McGoo01
Aug 23, 2015Aspirant
Hallo JamesGL,
actually my PC is already the 2nd PC I´ve tried, my son´s PC was the 1st one. And yes, the problem occurs
on both PCs.
McGoo01
