CAPRDN
Aug 09, 2015Aspirant
WNDA3100v2 works intermittently with windows 10
My N600 Wireless USB adapter, which has worked great for a couple of years on Windows 8.1, keeps turning off after the upgrade this week to Windows 10. I downloaded the latest version of drivers ...
- Aug 11, 2015
KMccart wrote:I am having the same problem with mine as well. The driver version it says I am using is 5.100.68.29 from the date 10/13/2010 even though I redownloaded the device driver utility today and ran it. Under the "events" tab of the device information it also has a message saying it requires further installation. It shows that a device install was requested today but I am guessing it didn't properly update?
I finally gave up on trying to get the Netgear to stop dropping the connection. Everything I read on the web said to wait for better drivers and in the meantime convert back to Windows 8.1.
Before I did that I went to Staples and bought the Linksys AC1200. They said I had 14 days to test it and return it if necessary. Well it has been a few hours and no dropped connection! Perhaps it is the AC protocol vs. the older one with the Netgear and how it communicates with my Apple router. Not sure but so far so good! I will update this post if/when the connection drops but for now my fingers are crossed! If it works it is worth the extra bucks for a new adapter.
aneedham
Sep 02, 2015Aspirant
I'm sorry to say that I am having the same problems. Just upgraded to Windows 10 last weekend from Windows 7.
My WNDA3100v2 kept randomly losing access to the default gateway or stopping altogether. I have upgraded the driver to 5.100.148.6 and still no luck.
Going to troubleshoot some more tonight. I'm wondering whether it has something to do with the USB drivers after doing some further googling.
JamesGL
Sep 04, 2015NETGEAR Employee Retired
Hi aneedham,
Make sure firewall or antivirus is disabled when doing testing. If it works then try to check how to excempt the adapter on your antivirus or firewall.
JamesGL
Community Team
- aneedhamSep 05, 2015Aspirant
Thanks for the sugestion JamesGL tried had tried that initially with no luck.
- BaJohnSep 06, 2015Virtuoso
I would still like to know why did Netgear provide a genie product as Vers 2.2.0.5 and a standalone (not Genie) at Vers 2.2.0.6.
You cannot install one after the other (in either order) and not get problems, but the implications is that there is a later driver than that for Vers 2.2.0.5.
All the notes and things I have read have not explained this. Maybe one version is for Windows 7, 8, 8.1 whilst the other is for Winows 10, but it isn't clear.
For Windows 10 should we ALL install the Vers 2.2.0.6 the latest?
More info required on the 2 options please?
- BaJohnSep 07, 2015Virtuoso
If Version 2.2.0.5 is NOT the latest version, with 2.2.0.6 available, why when I have the2.2.0.5 installed do I get the following on check for software update:-
2015/09/07 11:09:51 : Check for software update from Netgear server.
2015/09/07 11:09:52 : Your software is up-to-date.i.e. why does it not tell me to upgrade to Version 2.2.0.6?
