CAPRDN
Aug 09, 2015Aspirant
WNDA3100v2 works intermittently with windows 10
My N600 Wireless USB adapter, which has worked great for a couple of years on Windows 8.1, keeps turning off after the upgrade this week to Windows 10. I downloaded the latest version of drivers ...
- Aug 11, 2015
KMccart wrote:I am having the same problem with mine as well. The driver version it says I am using is 5.100.68.29 from the date 10/13/2010 even though I redownloaded the device driver utility today and ran it. Under the "events" tab of the device information it also has a message saying it requires further installation. It shows that a device install was requested today but I am guessing it didn't properly update?
I finally gave up on trying to get the Netgear to stop dropping the connection. Everything I read on the web said to wait for better drivers and in the meantime convert back to Windows 8.1.
Before I did that I went to Staples and bought the Linksys AC1200. They said I had 14 days to test it and return it if necessary. Well it has been a few hours and no dropped connection! Perhaps it is the AC protocol vs. the older one with the Netgear and how it communicates with my Apple router. Not sure but so far so good! I will update this post if/when the connection drops but for now my fingers are crossed! If it works it is worth the extra bucks for a new adapter.
Bhankhai
Sep 08, 2015Initiate
I think I have solved this, on my machine anyway. I uninstalled all the drivers and reinstalled the Windows 8.1 drivers. I unticked "Allow the computer to turn off this device to save power" box on Device Manager/Network Adapter/Power Management.
Hope this helps.
Bhankhai
Definitely works. Five hours uptime with constant use and no drops at all.
- BaJohnSep 13, 2015Virtuoso
Still unsure why there are different versions of the software available.
Obviously no one from Netgear reads these posts.
Made a decision to rebuild my PC from scratch.
Disillusioned.
- JamesGLSep 15, 2015NETGEAR Employee Retired
Hi BaJohn,
Welcome to Community!
The filenames are different but once installed, they have the same driver version.
JamesGL
Community Team
- BaJohnSep 15, 2015Virtuoso
So there is no point in installing the Vers 2.2.0.6 if you have installed the 2.2.0.5 software?
