CAPRDN
Aug 09, 2015Aspirant
WNDA3100v2 works intermittently with windows 10
My N600 Wireless USB adapter, which has worked great for a couple of years on Windows 8.1, keeps turning off after the upgrade this week to Windows 10. I downloaded the latest version of drivers ...
- Aug 11, 2015
KMccart wrote:I am having the same problem with mine as well. The driver version it says I am using is 5.100.68.29 from the date 10/13/2010 even though I redownloaded the device driver utility today and ran it. Under the "events" tab of the device information it also has a message saying it requires further installation. It shows that a device install was requested today but I am guessing it didn't properly update?
I finally gave up on trying to get the Netgear to stop dropping the connection. Everything I read on the web said to wait for better drivers and in the meantime convert back to Windows 8.1.
Before I did that I went to Staples and bought the Linksys AC1200. They said I had 14 days to test it and return it if necessary. Well it has been a few hours and no dropped connection! Perhaps it is the AC protocol vs. the older one with the Netgear and how it communicates with my Apple router. Not sure but so far so good! I will update this post if/when the connection drops but for now my fingers are crossed! If it works it is worth the extra bucks for a new adapter.
Blayd
Oct 02, 2015Aspirant
I may not have been clear. I COULD NOT uninstall the genie software at all. Could not uninstall using device manager or windows Programs. I WAS able to uninstall the adapter driver from device manager, but reloading the updated stand alone driver still did not work. Since I was unable to get online, letting windows look for a driver was not an option. When trying to uninstall the updated genie software, I got nothing but errors, stopping the uninstall. Since the buggy upgrade left me with no way to get online and find a solution to uninstall the bad update, I had no choice but to revert back to Windows 7 Pro through the Windows 10 revert back option, to see if I could get my adapter working again. That was worse, as Windows 10 revert option is still very buggy. I got back Windows 7 Pro, but had no mouse or keyboard drivers loaded. Basically dead in the water. So I had to wipe the HD clean, and do a clean install of Windows 7 Pro to get things back to normal. Now I'm trying to get Windows update to work properly and recognize my free update back to 10 at some point.
