CAPRDN
Aug 09, 2015Aspirant
WNDA3100v2 works intermittently with windows 10
My N600 Wireless USB adapter, which has worked great for a couple of years on Windows 8.1, keeps turning off after the upgrade this week to Windows 10. I downloaded the latest version of drivers ...
- Aug 11, 2015
KMccart wrote:I am having the same problem with mine as well. The driver version it says I am using is 5.100.68.29 from the date 10/13/2010 even though I redownloaded the device driver utility today and ran it. Under the "events" tab of the device information it also has a message saying it requires further installation. It shows that a device install was requested today but I am guessing it didn't properly update?
I finally gave up on trying to get the Netgear to stop dropping the connection. Everything I read on the web said to wait for better drivers and in the meantime convert back to Windows 8.1.
Before I did that I went to Staples and bought the Linksys AC1200. They said I had 14 days to test it and return it if necessary. Well it has been a few hours and no dropped connection! Perhaps it is the AC protocol vs. the older one with the Netgear and how it communicates with my Apple router. Not sure but so far so good! I will update this post if/when the connection drops but for now my fingers are crossed! If it works it is worth the extra bucks for a new adapter.
Finally
Oct 21, 2015Initiate
Thanks Bhankhai, worked like a charm and no messing with drivers necessary.
For those who haven't tried, this is definitely worth a shot. It's the only real solution I've found.
Right click the start menu button >
Open control panel >
Hardware and sound >
Device manager >
Right click "NETGEAR WNDA3100v2 N600 etc" >
Properties >
"Power Management" tab >
Uncheck "Allow the computer to turn off this device to save power"
I'm pretty sure this is a new feature with Windows 10 so it makes sense that this would be causing most (if not all) of the problems.
Alibkm
Oct 22, 2015Aspirant
Exactly! I did this a month ago and have had no problems since. Very clearly explained. Everyone with this problem should READ THIS!
