JayeFive
Jan 04, 2019Aspirant
WNDA3100v3 causing BSOD on network connect Windows 10
I just made a clean install of Windows 10 on my machine:
EVGA 131-GT-E767 X58
Intel i7-950 Bloomfield
Windows 10 Pro
The only thing I've installed is the MoBo chipset which has window...
- Jan 12, 2019
Ah... finally... I've got it working.
Used a wired connection to update Windows 10 to v1809 and then installed WNDA3100v3 1.0.0.13 As Administrator (it could have been the As Administrator option that may have made all the difference, and not so much the Windows updates). No more BSODs this time.
Blanca_O
Jan 10, 2019NETGEAR Employee Retired
Hi JayeFive
Welcome to NETGEAR Community!
Can you please try installing your WNDA3100v3 adapter while your Windows 10 computer is in Safe Mode with Networking? The steps on how to boot your computer to the mode I recommended is outlined here: https://support.microsoft.com/en-ph/help/12376/windows-10-start-your-pc-in-safe-mode
Blanca
Community Team
TachyonDreams
Jan 12, 2019Initiate
- JayeFiveJan 13, 2019Aspirant
Tachyon,
Glad you got it working. I'll try this approach at some point. This is way off topic, but I still can't understand why Microsoft decided to assume every machine is a shared workspace when they integrated NT into the mainstream design. The whole 'run as admin' concept doesn't make any sense for a workspace that only one person ever uses and causes all kinds of problems everytime windows introduces a new iteration.
