Frazzled14
Aug 05, 2016Aspirant
WNDA3100v3 constantly losing connectivity
Hi All, Internet connectivity has been appalling recently with this device. We are trying all sorts here trying to fix it and have even been back to the shop we purchased it in! I have asc...
JamesGL
Aug 11, 2016NETGEAR Employee Retired
Hi Frazzled14,
Check the driver is on the latest by visiting support site. You may uninstall it and reinstall using the standalone driver.
https://www.netgear.com/support/product/WNDA3100v3.aspx?cid=wmt_netgear_organic#Software Version 1.0.0.10 (Supports Win10)
JamesGL
Community Team
- Frazzled14Aug 12, 2016Aspirant
Thanks for your reply James. I'd already checked and believed that I had the current up-to-date drivers, both before and after re-installation but wasn't sure. We gave up in the end and brought the adapter back to the store to replace as it was still under warranty.
I have saved your answer in case this one acts up too!!
