boourns
Jan 05, 2016Aspirant
WNDA3100v3 on Windows 10 Not Enabled
I recently upgraded my OS from Windows 7 to 10. My WNDA3100v3 wifi adapter worked perfectly with 7, but has had issues with 10. After not being able to connect, I uninstalled my driver and reinstalle...
JamesGL
Jan 06, 2016NETGEAR Employee Retired
Hi boourns,
Uninstall the driver of the adapter. Reinstall it using the standalone driver. Disable antivirus or firewall for the mean time while installing the adapter.
