DrLove38
Aug 19, 2015Tutor
WNDA3100v3 on Windows 10
Hello, I bought a WNDA31000v3 adapter after reading on Netgear support that it would work with Windows 10. My WN111 was not reconnecting after sleep and on start up. It would work if you reconnecte...
JamesGL
Aug 21, 2015NETGEAR Employee Retired
Hi DrLove38
Please try to install the driver manually. But first, remove the installed drivers and software.
1. Install the WNDA3011v3_v1.0.0.10 software.
2. Once installed, manually update driver software. Open Device Manager , select the WNDA3011v3, right click , select Update Driver Software.
3. Choose Browse my computer for driver software
4. Choose Let me Pick from a list of device drivers on my computer
5. Select the one with NETGEAR INc.
JamesGL
Community Team
PERO
Aug 23, 2015Aspirant
My PC can se my "stick", WNA3100M. I have downloaded the latest ver, but the PC still ask for the drivers.
PERO
