Ocade
Apr 25, 2017Aspirant
WNDA3100v3 Orange/amber Light most of the time with blue light sometimes
Hello, I bought a WNDA3100v3 N600 not long ago and I'm having problems. More often that not the light indicator is orange and I have a low ping of sub 10 ms with spikes at 800 ms or small disconn...
JamesGL
May 08, 2017NETGEAR Employee Retired
Hi Ocade,
Do you have a NETGEAR Genie installed on your computer? If yes, you can use it to check the networks. Orange means it is connected to 2.4Ghz.
