Ocade
Apr 25, 2017Aspirant
WNDA3100v3 Orange/amber Light most of the time with blue light sometimes
Hello, I bought a WNDA3100v3 N600 not long ago and I'm having problems. More often that not the light indicator is orange and I have a low ping of sub 10 ms with spikes at 800 ms or small disconn...
JamesGL
May 08, 2017NETGEAR Employee Retired
Hi Ocade,
Do you have a NETGEAR Genie installed on your computer? If yes, you can use it to check the networks. Orange means it is connected to 2.4Ghz.
JamesGL
May 17, 2017NETGEAR Employee Retired
Hi Ocade,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
