Ocade
Apr 25, 2017Aspirant
WNDA3100v3 Orange/amber Light most of the time with blue light sometimes
Hello, I bought a WNDA3100v3 N600 not long ago and I'm having problems. More often that not the light indicator is orange and I have a low ping of sub 10 ms with spikes at 800 ms or small disconn...
JamesGL
May 08, 2017NETGEAR Employee Retired
Hi Ocade,
Do you have a NETGEAR Genie installed on your computer? If yes, you can use it to check the networks. Orange means it is connected to 2.4Ghz.
Ocade
May 31, 2017Aspirant
Hello, sorry for the late answer.
Yes I have NETGEAR Genie, what do you mean by checking the networks? If by that you mean accessing the right network, I did I chose the only network corresponding.
Here is what I can get when clicking on it.
I blurred the mac adress because while I don't know much about this stuff I don't think you'd need it.
- JamesGLJun 15, 2017NETGEAR Employee Retired
Hi Ocade,
Check if you are connected to 2.4Ghz network or 5Ghz network.- OcadeJun 16, 2017Aspirant
How ?
- JamesGLJun 20, 2017NETGEAR Employee Retired
Hi Ocade,
Do you know the names of your wireless network?
- OcadeJun 26, 2017Aspirant
Isn't it Livebox 2B9E like shown here? http://imgur.com/a/wyMLd
