Ocade
Apr 25, 2017Aspirant
WNDA3100v3 Orange/amber Light most of the time with blue light sometimes
Hello, I bought a WNDA3100v3 N600 not long ago and I'm having problems. More often that not the light indicator is orange and I have a low ping of sub 10 ms with spikes at 800 ms or small disconn...
Ocade
May 31, 2017Aspirant
Hello, sorry for the late answer.
Yes I have NETGEAR Genie, what do you mean by checking the networks? If by that you mean accessing the right network, I did I chose the only network corresponding.
Here is what I can get when clicking on it.
I blurred the mac adress because while I don't know much about this stuff I don't think you'd need it.
JamesGL
Jun 15, 2017NETGEAR Employee Retired
Hi Ocade,
Check if you are connected to 2.4Ghz network or 5Ghz network.
- OcadeJun 16, 2017Aspirant
How ?
- JamesGLJun 20, 2017NETGEAR Employee Retired
Hi Ocade,
Do you know the names of your wireless network?
- OcadeJun 26, 2017Aspirant
Isn't it Livebox 2B9E like shown here? http://imgur.com/a/wyMLd
- OcadeSep 07, 2017Aspirant
Hello again, would like to add that during those few months it worked perfectly somehow. I had a bright blue light permanently but today without anything changing the light is back to amber and I get high ping spikes.
Any idea?
