Chiakyi's avatar
Chiakyi
Follower
Aug 03, 2016
wnda3100v3 Sudden Highping!!!
Hey Netgear Community,
so i recently bought the netgear N600 WiFi USB Adapter, because my last wlan adapter was broken (literally). But since i got this USB adapter, i get sudden high pings especially in online games (like Overwatch or Counter Strike GO). The confusing part is that i normally got a ping between 20ms - 40ms, but there are some sudden pings like 2000ms once in a while, which make it harder to play any online games! I updated the drivers and also tested my connection with another Wlan Stick, which i had no problem with. So i guess there is a hardware problem and i dont know how to fix it.
I hope for a quick answer!
Cheers,
Chiakyi
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi Chiakyi,
    Uninstall the driver of the adapter and reinstall it using the standalone driver.
    JamesGL
    Community Team
  • JamesGL's avatar
    JamesGL
    Hi Chiakyi,
    We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
    If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
    JamesGL
    Community Team
