tfox37380's avatar
tfox37380
WNDA3100v3 won't work with Dish cable tv receiver
My brother-in-law uses a 3100v2 adapter to connect his Dish cable tv receiver to the internet and it works fine. When I try this 3100v3 adapter, the dish receiver says this USB device is not compatible with the receiver. How to fix?
  • Hi tfox37380,
    The adapter only works with the windows based OS computers and does not work with other devices. If the receiver has ethernet port, I would suggest WNCE2001, WNCE3001 and WNCE4004.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi tfox37380,
    • tfox37380's avatar
      tfox37380
      Is it possible to revert v3 to v2 by using v2 software download?
    • JamesGL's avatar
      JamesGL
      Hi tfox37380,
      The drivers for v2 will not work with v3 and vice versa.
      • JamesGL's avatar
        JamesGL
        Hi tfox37380,
        We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
