wendywenz
Jun 10, 2016Aspirant
WNDA3200 DRIVER
Hi there, Having problems with Netgear Wireless 11N Dual Band USB Adapter WNDA3200 on my Windows 10. It doesnt seem to be installed or showing any driver for it. Ive searched here for the driver b...
JamesGL
Jun 15, 2016NETGEAR Employee Retired
Hi wendywenz,
1. What is the exact model number of your adapter?
2. If it is WNDA3200, where did you purchase it?
wendywenz
Jun 16, 2016Aspirant
Hi JamesGL,
1. NETGEAR WNDA3200 Wireless 11N Dual Band USB Adapter
2. It came from Virgin Media
It worked with my older computers. Winxp, Win7, but not with my new Win10
I bought a new one from Amazon thinking my old one was damaged but it doesnt work. I am assuming theres no driver installed on my Win10 PC
Thanks
Wendy
- wendywenzJun 16, 2016Aspirant
These are the details from the Amazon site that I bought it from...
Product Description
This is a Netgear WNDA3200 This is brand new and is sealed in plastic and boxed . However the containing box has been opened to check content Includes USB extension lead. The WNDA3200 has the virgin brand logo on it but is in essence the same as the Netgear WNDA3100 v2. To install, just press the sync button. No CD/Software required. Wirelessly surf, email, stream HD video, on-line game, make Internet phone calls Less interference and better connections using dual band Wireless-N Better speed and range than other USB Wireless-N adapters Easy and secure wireless connections Works with older Wi-Fi as well as new Wireless-N networks Delivers consistent wireless connections using Dual Band Wireless-N Provides enough bandwidth to support music downloads, file sharing and HD multimedia applications Works with all new Wireless-N Gateways, Routers and Access Points Backward compatible with older Wireless-G hotspots Designed for your notebook or desktop PC Supports Windows® VistaTM
- JamesGLJun 21, 2016NETGEAR Employee Retired
Hi wendywenz,
This device is sold through Virgin Media and is now an EOL device. There will be no support for Windows 10 for EoL devices.
- JamesGLJun 26, 2016NETGEAR Employee Retired
Hi wendywenz,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
