Immortalwa
Sep 20, 2015Follower
WNDA4100 and Other Wireless Adapters Low Connection Speed, Failure to Connect at 5G, etc.
I have experienced extremely low connection speeds, seemingly dead adapters, and other problems with two adapters, the WNDA 4100 and WNDA3100 v.2. These have been caused by incompatible drivers autom...
Shankems
Nov 18, 2015Aspirant
The 2012 3.2.7.0 driver has terrible throughput. Netgear still has to get their act together. None of the newer versions work in win10 for me. Does anyone have a zipped version of the latest driver files, that work that can be passed around? (The actual files, not the installer trash netgear is publishing)
JamesGL
Nov 19, 2015NETGEAR Employee Retired
Hi Shankems,
Have you tried the windows 10 driver?
http://kb.netgear.com/app/answers/detail/a_id/30066
JamesGL
Community Team
- cintron2861Nov 20, 2015Aspirant
I was not aware of the new driver, this must had just come about in the past week, I had downloaded and installed the Windows 8.1 & 10 version 1.2.0.13 needless to say this did not work even though I did what I always do. un-install, remove adatpter after all is completely un-installed, restart, install new program and finally install adapter.
How ever I will try this one on Saturday to see if it functions, this is based of course if there is a verdion 1.2.0.14 driver for the WNDA4100 900.
- JamesGLNov 21, 2015NETGEAR Employee Retired
Hi Cintron2861,
Provide us an update once you have tried the new driver.
JamesGL
Community Team
