bonnier243
Dec 06, 2015Follower
WNDA4100 error on startup
Running Vista Home on Dell PC. Using Netgear N900 WiFi Dual Band USB adapter. Getting following error in startup: 'WNDA4100 Genie MFC Application has stopped working. A problem caused the pro...
- Dec 06, 2015
Hi bonnier243,
Please uninstall the genie utility of WNDA4100 and check if it has the same error.
JamesGL
Dec 06, 2015NETGEAR Employee Retired
Hi bonnier243,
- Doughboy72Dec 11, 2015Aspirant
How does one uninstall the Genie function but still maintain the ability to use the USB Wireless Connection. It seems I have only been able to uninstall the entire software suite thus far
- JamesGLDec 13, 2015NETGEAR Employee Retired
The genie is just a software you can use to connect to the network. If no genie, you can still use the windows utility to connect.
