bonnier243's avatar
bonnier243
Follower
Dec 06, 2015
WNDA4100 error on startup
Running Vista Home on Dell PC.  Using Netgear N900 WiFi Dual Band USB adapter.  Getting following error in startup:    'WNDA4100 Genie MFC Application has stopped working.  A problem caused the pro...
  • JamesGL's avatar
    Dec 06, 2015
    Hi bonnier243,
    Please uninstall the genie utility of WNDA4100 and check if it has the same error.
