bonnier243
Dec 06, 2015Follower
WNDA4100 error on startup
Running Vista Home on Dell PC. Using Netgear N900 WiFi Dual Band USB adapter. Getting following error in startup: 'WNDA4100 Genie MFC Application has stopped working. A problem caused the pro...
- Dec 06, 2015
Hi bonnier243,
Please uninstall the genie utility of WNDA4100 and check if it has the same error.
Doughboy72
Dec 11, 2015Aspirant
How does one uninstall the Genie function but still maintain the ability to use the USB Wireless Connection. It seems I have only been able to uninstall the entire software suite thus far
JamesGL
Dec 13, 2015NETGEAR Employee Retired
The genie is just a software you can use to connect to the network. If no genie, you can still use the windows utility to connect.
