ThomasGeisler
Jul 31, 2015Follower
Wnda4100 not found after Windows 10 upgrade
My WNDA4100 N900 WiFi USB adapter, that worked perfectly on windows 7 (64bit), has stopped working once I installed the windows10 upgrade . When using the installer it would say the adapter hasn't bee...
YardMan
Aug 01, 2015Aspirant
When I upgraded to Win 10 I first could not detect my 5ghz network and then when I tried re-installing the software I could not get my 2.4 ghz to work. No light, no nothing no internet. Seems Netgear could have seen this coming? What can I do to get back on the internet? Please help?
dreynt
Aug 02, 2015Initiate
This has happened at every successive version of windows - the adapter wouldn't work after upgrading from Windows 7 to Windows 8, same with upgrade to Windows 8.1 from 8, and now it seems that Netgear has done it again. I tried installing the drivers from the site, but if you look at the date on the driver following install, its a year old (Dated 6-6-2014) - which means it was not intended to work with Windows 10. The driver package is even called Win_8. What I fully expect to happen is that within a week or two Netgear will post a new driver package and then blame the whole fiasco on Microsoft--which has been their response for the past two upgrade fails.
