ThomasGeisler
Jul 31, 2015Follower
Wnda4100 not found after Windows 10 upgrade
My WNDA4100 N900 WiFi USB adapter, that worked perfectly on windows 7 (64bit), has stopped working once I installed the windows10 upgrade . When using the installer it would say the adapter hasn't bee...
marinecomm
Aug 03, 2015Aspirant
I'm having the same issue. When I try to install the standalone driver or the software at some point it freezes and won't complete the installation. If I go to the Device Manager the wifi adapter shows up. However, for the life of me I can't get it to work.
garyinfl
dreynt has the solution that worked for me... follow his steps
- marinecommAug 03, 2015Aspirant
Tried that but since the installation of the driver freezes it never fully loads the driver onto the system so there are no Netgear drivers to choose from.
