ThomasGeisler
Jul 31, 2015Follower
Wnda4100 not found after Windows 10 upgrade
My WNDA4100 N900 WiFi USB adapter, that worked perfectly on windows 7 (64bit), has stopped working once I installed the windows10 upgrade . When using the installer it would say the adapter hasn't bee...
marinecomm
Aug 03, 2015Aspirant
I'm having the same issue. When I try to install the standalone driver or the software at some point it freezes and won't complete the installation. If I go to the Device Manager the wifi adapter shows up. However, for the life of me I can't get it to work.
DarrenM
Aug 14, 2015Sr. NETGEAR Moderator
Hello marinecomm
The first thing I would do is make sure you have a the latest drivers from your PC manufactor for your usb ports. Second uninstall all of your netgear network adapters drivers then reinstall the latest driver without the usb adapter plugged into the pc. after you have install the drivers then try to plug the usb adapter back into the pc. We are also working on drivers so if this dosnt work let me know some info about your PC and what issues your still having.
1. Did you upgrade from windows 7 or 8 or did a clean install of win 10
2. Does your pc have amd or intel chipset
DarrenM
