bammon0001
Mar 20, 2018Aspirant
WNDA4100 won't show connections
My WNDA4100 won't show connections on the Windows 10 update. On an earlier version on another computer they come up fine.
I uninstalled Genie, then I uninstalled the driver in Driver Manager, then I re-installed
the Windows 10 version and the connections came up fine. Thanks to all the Device
Driver solutions I saw.
Does this mean that Windows will not show you which wifi sources are available?
If so, that sounds like a Windows thing rather than anything due to the wifi adapter.
Do you have the software that supports Windows 10?
There is software and a manual for the WNDA4100 somewhere at the end of this link:
>>>> WNDA4100 | Product | Support | NETGEAR <<<<
- bammon0001Aspirant
