jmc2000
Sep 21, 2015Aspirant
WPN111 doesn't work with Windows 10
I upgraded Windows 7 to 10 and things seemed initially fine. But after a while the WPN111 was no longer able to see any wireless networks, but the blue LED was still flashing. I reinstalled the WP...
- Sep 22, 2015
Hi jmc2000,
Welcome to Community!
The driver of WPN111 does not suppot Windows 10. That is the reason it will not work.
JamesGL
Community Team
Ku31179
Dec 07, 2015Initiate
Right click the wireless network icon in the lower right hand corner near the date and time, right click on "Troubleshoot problems", windows will search for the problem and then your WPN111 adapter should work. It worked for me, the only thing it changed was my networks name when I click on the wireless network icon. It's now called "Virtual Profile", but when I go into the "Network and Sharing Center", it shows my WPN111 connected to my home router.
Hope it works for you as it did for me,
Kris
