Jasonneal
Jun 06, 2016Follower
wps pin for ac1200 usb adapter
looking for wps pin for usb adapter my new printer is asking for it?
VE6CGX
Jun 06, 2016Master
Then you push the WPS button on the router. If WPS set up does not work you'll have to finish set up manually. WPS button could be hardware
button (actual push button switch) or software button you click in the router set up wireless section >> WPS.
