mikeosully1's avatar
mikeosully1
2.4 GHz WiFi devices not connecting to Nighthawk X65 AC3000 Tri-Band WiFi Range Extender
Pucrchased a Nighthawk X65 AC3000 Tri-Band WiFi Range Extender about a month ago, (and no I do not have a copy of the reciept) ...
I'm just now trying to set the extender up.
The Client Link LED lights up for my 5 GHz devices, but the LED will not for my 2.4GHz devices.  (And there appears to be no range gain for my 2.4GHz devices)
So how do I get my 2.4GHz devices to connect to the Extender?
Any help or suggestions would be greatly appreciated.
Thanks, and best regards,
Michael
  • The WPS connection worked for the 5GHz connection but not for the 2.4GHz connection.
    I had to log into the extender and set up the 2.4GHz connection
1 Reply
