Jan 11, 2016Aspirant
2 Wifi Extenders ?
Hi , am not too pc savvy so please bear with me .....have a Netgear EX2700 wifi extender installed , it has improved my internet connection downstairs but still get the occasional buffering , so was...
TheEther
Jan 11, 2016Guru
"Piggy backing" extenders wirelessly is strongly discouraged. The performance drop (75% or more) will likely be unacceptable.
You can, however, connect as many extenders as you want off of an Ethernet or Powerline network that is connected back to your router. This is the ideal setup without the performance penalty associated with wireless extenders.
24008943
Thanks for the prompt reply ...can you tell me what Netgear extender gives out the strongest signal please ?
- TheEtherJan 11, 2016Guru
I personally have not used any of Netgear's extenders. The EX7000 advertises 700mW amplifiers, so it probably has good range. It's pretty pricy and your mileage may vary, so do your own research and make sure it meets your needs and budget.
BTW, I notice that Netgear just released two new extenders: the EX7300 and the EX6400.
- 24008943Jan 11, 2016Aspirant
Thanks for the info, will take peek a them .
