kaliharry
Sep 21, 2016Aspirant
2 x EX7000 with BT Infinity Hub
I have just had BT fibre Infinity put into old stone house with 10 bedrooms used as a guest house. In order to ensure good wifi coverage I purchased 2 x EX 7000 to spread wifi to as many spots as po...
- Sep 21, 2016
Most likely due the fact that it's an older home with lath and plaster constructed walls (not conducive to wifi), and maybe some stone walls in the house also? Irregardless, the best way to extend wifi is configuring the EX7000's as Access Points, using Ethernet cable to connect back to the BT router, allowing the BT router to provide DHCP to your network. Otherwise you will be struggling to keep the EX7000's connected to yout BT router.
netwrks
Sep 21, 2016Master
kaliharry
HI
Thanks for that really helpful ... so I run an ethernet from both each of EX 7000's back to hub and that's all I need do or is there additional setting up?
It is an old stone house (1670) and so always a nightmare.
Thanks
John
