romain3369
Dec 28, 2016Follower
29% power with N300, would it be better with AC1200 ?
Hi community ! I have installed a N300 WiFi extender but the connection is bad. I have only 29% signal power between my router and my extender ! If I replace the N300 for a AC1200, would I h...
DarrenM
Dec 30, 2016Sr. NETGEAR Moderator
Hello romain3369
You may want to try and change your wireless channel on your router it should be in the wireless settings to see if you can get a better connection.
DarrenM
