hassaninho
Nov 10, 2019Aspirant
5ghz wrong channel
I am very disappointed of this product. I have tested everything. My 5Ghz is not working because the extender is giving the channels between 100 and 140. My devices can't support that. I have tes...
hassaninho
1. Extender Mode.
2. No, they are not even on the list of 5ghz. I can only choose 100 to 140 on that list.
My routers channel for 5ghz is 36 but the netgear extender change it to 100 - 140
3. 1.0.0.52
4. Europe
3. 1.0.0.52
4. Europe
Nov 10, 2019Guru - Experienced User
For testing, if you enable access point mode (direct wire it), are you able to choose 32-48?
What do you mean that your extender changes it to 100-140? It changes your primary router's broadcast channel?
