hassaninho
Nov 10, 2019Aspirant
5ghz wrong channel
I am very disappointed of this product. I have tested everything. My 5Ghz is not working because the extender is giving the channels between 100 and 140. My devices can't support that. I have tes...
Nov 10, 2019Guru - Experienced User
It is working but not how you'd like it to.
I recommend 3 that'd work better for you in the prior post
hassaninho
i dont really know if you understand what i mean.
The only thing i want to do is tho extend my 5Ghz wifi signal.
I use channel 36 in my router, I just want to extend it using my EX7500.
Why cant i do that ?
- plemansNov 10, 2019Guru - Experienced UserBecause the only radio that broadcasts on those channels is being used for the wireless backhaul. Not sure how else to explain it.
- hassaninhoNov 10, 2019AspirantOk but how does the 2.4 working.? It's also already used but the extender used same channel.
