gphorce5
Jul 15, 2016Aspirant
6100 Extender setup
When I purchased this model in December I called a customer service rep and they kindly helped me set it up. My internet provider recently upgraded my modem/router and now I don't remember how to se...
DexterDog
Have you had any luck yet? The reason I ask is that my extender would not connect to my router, i got disgusted and forgot about it. Now my 90 days of techincal support has run out. I'm dead in the water. Looking for help. Thanks, Tim
gphorce5
Jul 16, 2016Aspirant
Tim, I haven't had any luck. I'm just running off my router. I'm going to look into linksys, they don't charge for customer service after 90 days.
- DarrenMJul 18, 2016Sr. NETGEAR Moderator
Hello gphorce5
You will want to do a factory reset of the extender by holding down the reset button on the device for 10 seconds then you can do the setup again which I linked a guide on how to do this.
http://www.downloads.netgear.com/files/GDC/EX6100/EX6100_QSG_24sep2015.pdf?cid=wmt_netgear_organic
DarrenM
