hartflush
Sep 24, 2016Aspirant
AC 1200 Range Extender MAC book pro shows "ip address assigned automaticly" and won't connect to net
The set up went off without a hitch. I can see the extender in my networl preferences, but my MAC BookPro won't connect to it. I get an error message in the network preferences saying "ip address a...
hartflush
I should have started with a big THANK YOU for the response!
Here is the message I get post set up: "Wi-Fi has the self-assigned IP address 169.254.231.116 and will not be able to connect to the Internet."
TheEther
Sep 24, 2016Guru
Do you have access control enabled on your router? If so, your Mac and iPad will appear as different devices when connected through the extender.
- hartflushSep 25, 2016Aspirant
I don't know what access control is. I've not changed any of the settings on the router. Whatever base Fios settings it came with are unchanged.
I'm about ready to box this up and ship it back. . .
- TheEtherSep 25, 2016Guru
Access control might be called Wireless MAC Authentication on a FIOS router. Are you using it?
If you log into your FIOS router, does it see the extender as an attached device?
