nathalia
Jan 30, 2019Aspirant
AC 1900 WiFi Range Extender EX7000
the extender seamed to never have worked as good as i hoped, but lately i can't even access the extender itself through the webbrowser.
i got an email, that said, i needed to download an impor...
Christian_R
Jan 31, 2019NETGEAR Employee Retired
Hi nathalia,
Hard reset the extender and join the NETGEAR_EXT wifi network. After you connect to it, you'll be able to browse to www.mywifiext.net and update the firmware.
~Christian
nathalia
Jan 31, 2019Aspirant
Thanks Christian,
Hard reset, you mean the little pin hole, right? i did that and then reconnected the extender with the router. i still can't access it?! not sure why
- Christian_RJan 31, 2019NETGEAR Employee Retired
Hello nathalia,
When you hard reset the extender are you able to locate the wifi network named "NETGEAR_EXT" using a laptop or mobile device?~Christian
- nathaliaFeb 07, 2019Aspirant
Hi Christian,
Yes i can locate all the connections and connect to them just fine, i am just not able to log into my extender and update the software
- Christian_RFeb 08, 2019NETGEAR Employee Retired
Hi nathalia,
Connect to the NETGEAR_EXT network and log into the extender's admin page using the default credentials (Username: admin - Password: password)
~Christian
