jameshi
Dec 02, 2017Follower
AC 750 wi-fi range extender bricked after firmware update, no wi-fi or ethernet access
Since being prompted to upgrade firmware on my EX3700 AC750 range extender I can not access the device, it does not emit a wifi signal nor can I get to it using an ethernet cable, I've tried a hard reset but that has no effect.
All I see is a blinking green power light.
Any ideas how I can get it working again?
- MarshywInitiate
My ac 750 did exactly the same thing after I updated firmware. All I get is a flashing green power light. Has anyone else had this problem or how can I fix this?
jameshi wrote:Since being prompted to upgrade firmware on my EX3700 AC750 range extender I can not access the device, it does not emit a wifi signal nor can I get to it using an ethernet cable, I've tried a hard reset but that has no effect.
- DarrenMSr. NETGEAR Moderator
You may have to reflash the firmware again here is a guide how to do it using TFTP.
https://kb.netgear.com/22688/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP
DarrenM
